Z22 Head
fullthrottle
Gday My mate has a pretty good datto 720 duel cab with a z22 in it and has found out the head is beyond repair( not sure on exactily whats wrong with it but the head shop said its no good to rebuild). The problem is noone can find another head for a z22 in Adelaide if anyone either has one laying around or a complete motor or anyothe suggestions eg swap a complete L18/20 motor in it if it would be easier any ideas will be great.
Help another datto live.
  • Replies 11
That will definitely bump it up but will require a complete changing of timing chain cover, timing chain, manifolds, carb?, throttle cable, down pipe. And the L head air filter will be in the way of the 720s master cylinder.
The Z22 is oriented about 8 degrees to the right of vertical as viewed from the front. The L series engine is oriented 12 degrees to the left of vertical. If you instal an L head on a Z series engine the intake and exhaust, being on the right will likely not have room to fit. The carb will also be tilted almost 20 degrees down towards the front wheel, like permanently driving with two wheels up on the curb. This can be remedied by using L series engine mounting brackets to tilt the Z22 block over to the (in your case diver's side) The problem with this is the transmission will also rotate and place the shifter into your right hip and tear out the rubber mount. This can be fixed by replacing the transmission with one for an L series engine. Complicated isn't it.
