Aazrin Posted July 20, 2014 Report Share Posted July 20, 2014 Been having cooling problems. Think it's the fan clutch but figured I'd update the whole system. After some googling I found these. http://www.oplautoparts.com/#!product/prd1/1163441211/hpr051_nissan-datsun_stanza-620-75-79' Anyone have any experience with them or know of a better option? Would like if it was direct fit as I don't know how or have the stuff to weld aluminum. Oh and they have it listed on Amazon which is where I found it. http://www.amazon.com/gp/aw/d/B00EOYQC82?pc_redir=1404656881&robot_redir=1 Quote Link to comment
Z-train Posted July 21, 2014 Report Share Posted July 21, 2014 How about you trouble shoot first.Mighty expensive if you "thought" wrong.Also,I havew doubts about it being a 3 row ALUMINUM radiator.It could be but odds are against it. Quote Link to comment
Aazrin Posted July 23, 2014 Author Report Share Posted July 23, 2014 Fan clutch is just a best guess without tarring stuff apart. But yes we really don't know for sure what the problem is. I've been wanting to upgrade the radiator anyway tho so I thought I'd see what was out there while I'm digging into the cooling system. What makes you question OPL? I've not delt with any aftermarket companies yet in my new tinkering adventure. Is there a obvious red flag I'm not seeing? Quote Link to comment
banzai510(hainz) Posted July 23, 2014 Report Share Posted July 23, 2014 I think later 620 rads were 3 core anyways. I would ck swap out the stat first maybe to a lower one or get rad cked first. ck the lower hose to make sure it dont collaspe under a load CSF rads from singapore are the worst!!!!!!!! 1 Quote Link to comment
Z-train Posted July 24, 2014 Report Share Posted July 24, 2014 Brass/copper radiators are three row.MOST aluminum are two or one core. 1 Quote Link to comment
Llittle_Llama Posted July 25, 2014 Report Share Posted July 25, 2014 Unless yours is destroyed (and even then it still might be salvageable) I would keep running it. Try to find the actual cause and if and when you decide the radiator needs replacing try to find a shop that can repair or rebuild it ;) 2 Quote Link to comment
