Dilligaf Posted July 6, 2014 Report Share Posted July 6, 2014 Ok im going to be removing my cab this weekend (12th) just wondering if there's any thing i should know that may slow me down? or is it alot like the 720 cab. And is anyone interested in RHD chassis parts as i will probably just be scrapping it. Quote Link to comment
bonvo Posted July 6, 2014 Report Share Posted July 6, 2014 you have the j series engine right? Quote Link to comment
datzenmike Posted July 6, 2014 Report Share Posted July 6, 2014 Steering box and column is all one piece so remove steering wheel and slide cab up back and off column or disconnect the pitman arm and box from frame and try sliding it down and out of truck. Remove... Rad Battery Cab seats Disconnect... Front brake lines Clutch slave flex hose Emergency brake cable Speedo cable Gas tank vent line to charcoal canister Throttle cable Electric choke and idle cut (if eequipped Alternator Oil pressure sender Water temp sender Reverse lamp wire harness from engine harness Starter solenoid wire Distributor Coil high tension wire. Quote Link to comment
Dilligaf Posted July 7, 2014 Author Report Share Posted July 7, 2014 might disconnect the pitman arm and steering box off the frame as im using a hoist so might be a bit easier that way. Quote Link to comment
