tmac1991 Posted May 30, 2014 Report Share Posted May 30, 2014 Hey guys I have a question that is probably a stupid one. But is there any way to bag the front suspension of my truck and be able to use the stock control arm and all. Any help would be nice. Thanks Quote Link to comment
Guest Rick-rat Posted May 30, 2014 Report Share Posted May 30, 2014 The only help I can offer is to search in Ratsun, someone has probably done it so info would be there Quote Link to comment
flatcat19 Posted May 30, 2014 Report Share Posted May 30, 2014 Oooo...2 threads about the same thing. Thd best help I can offer you is to check out InfamousNissans.com. Lots of bagged trucks and good info. Quote Link to comment
ggzilla Posted May 30, 2014 Report Share Posted May 30, 2014 Or read the replies to your original question Photos, links and comments have been given. Quote Link to comment
kaoss Posted May 30, 2014 Report Share Posted May 30, 2014 Are the 78s ball joint or kingpin trucks? If it's a king pin your limited to the size of tire you can run. check the link below, you can fit smaller bags in without much work, but with the weight of the v8 you may want to run a bigger bag. http://www.minitruckinweb.com/tech/suspension/1202mt_air_bagging_1973_datsun_bulletside/ I'm running a 6" bag, check my build thread and see what I had to cut. Quote Link to comment
tmac1991 Posted May 31, 2014 Author Report Share Posted May 31, 2014 Thanks kaoss Quote Link to comment
tmac1991 Posted May 31, 2014 Author Report Share Posted May 31, 2014 And the 78 is a balljoint truck Quote Link to comment
kaoss Posted May 31, 2014 Report Share Posted May 31, 2014 With it being ball joint figure out what it takes to run a d21 drop spindle. Free 2" right there, you'll need it. Quote Link to comment
tmac1991 Posted May 31, 2014 Author Report Share Posted May 31, 2014 Im not rele worried about going lower, really just want to get rid of my torsion bars Quote Link to comment
flatcat19 Posted May 31, 2014 Report Share Posted May 31, 2014 That's a completely different topic altogether. Quote Link to comment
Guest Rick-rat Posted June 1, 2014 Report Share Posted June 1, 2014 Put coil overs on the front, if you don't want to go really low Quote Link to comment
kaoss Posted June 2, 2014 Report Share Posted June 2, 2014 Im not rele worried about going lower, really just want to get rid of my torsion bars Then put coil overs on it, it's not worth the trouble for bags and air management if you aren't interested in instant adjustability. User Beebani sells a kit for this. Quote Link to comment
tmac1991 Posted June 3, 2014 Author Report Share Posted June 3, 2014 I kno he does Quote Link to comment
flatcat19 Posted June 3, 2014 Report Share Posted June 3, 2014 I kno he does Then why are you even asking? Do work. Quote Link to comment
tmac1991 Posted June 3, 2014 Author Report Share Posted June 3, 2014 Because everyone doesn't have tht kinda money just on upper control arms, then buying the shocks at 250 each. I can't get air bags cheaper. Quote Link to comment
wayno Posted June 4, 2014 Report Share Posted June 4, 2014 Because everyone doesn't have tht kinda money just on upper control arms, then buying the shocks at 250 each. I can't get air bags cheaper. Deleting the torsion bars is going to take money and effort, keeping the torsion bars and getting it low will take money or effort, it really depends on if you have a welder and know how to use it, and what type of ride your willing to live with. Quote Link to comment
