ANDREW5373 Posted May 20, 2014 Report Share Posted May 20, 2014 i have a 1980 datsun 210 and im needing to swap the whole front suspention i know its passible with some z but what type os z and what years... my brake caliper was leaking and cant find a rebuold kit or a new caliper....please help Quote Link to comment
ggzilla Posted May 20, 2014 Report Share Posted May 20, 2014 Remanufactured caliper is $18. Don't even bother trying to rebuild it. http://www.rockauto.com/catalog/x,carcode,1208821,parttype,1704 Available locally too http://m.napaonline.com/parts/PartsList.aspx?t=%3fNtt%3d%26Ntk%3dCategory%26N%3d599001%2b101980%2b50018%2b2018006%2b4018006%2b5999999%2b26591%26Ne%3d25000 Quote Link to comment
ANDREW5373 Posted May 21, 2014 Author Report Share Posted May 21, 2014 also if i keep the same setup im looking for the stock rotors they have a little flare on the inside were the bearing and seal do...all aftermarket one i buy for it are just straight rotors like on a newer car no bearing inside...any help...maybe previous owner swaped them out idk Quote Link to comment
ggzilla Posted May 21, 2014 Report Share Posted May 21, 2014 NAPA sell the rotors Oreillys Autozone Rock auto Or get yours turned. 210 have a separate hub with bearing. The rotors bolt to the hub. Quote Link to comment
floyd17 Posted May 30, 2014 Report Share Posted May 30, 2014 does the entire 280zx strut assembly bolt into the 210 with the springs cut? Quote Link to comment
ggzilla Posted May 30, 2014 Report Share Posted May 30, 2014 No but the strut assembly has to be modified. Basically grind the lower perch off and weld the 210 perch to the ZX strut. You can use the 210 spring uncut. Or use cut springs from rear of 280ZX. 1 Quote Link to comment
COOCHaDAMus Posted June 2, 2014 Report Share Posted June 2, 2014 No but the strut assembly has to be modified. Basically grind the lower perch off and weld the 210 perch to the ZX strut. You can use the 210 spring uncut. Or use cut springs from rear of 280ZX. that answers my long time question too. thank jedi master zilla. Quote Link to comment
