SU linkage rotation question
So we tried working this out using paper and felt pens but i can't seem to think it through correctly. And before we cut/grind it off to weld onto middle bar ( don't know technical name) between carbs.
My question is, if my linkage cable can only pull from A to B which circle would rotate more ,,as in turn farther..
The pink circle or the blue circle
I understand it is probably a simple answer but my brain is fried from measuring a million other things to use original cable that is just barely long enough.
  • Replies 7
Its really hard to pedal but you go fast in gear 7 on a mountain bike, and its easy to pedal but you go slow in gear 1. Gear 1 is big, gear 7 is tiny, Gear 1 has a large radius, gear 7 has a small radius.
Blue has a smaller radius.
Middle bar is the throttle bar
You'll have more than enough rotation in the stock (blue) trunnion hole.
Pulling from the top with 38s?
I did the same thing...but pulling from the bottom for the 46s to utilize my 'stock' throttle cable
Lower right in pic
Like a pry bar (or pen you're drawing with) the further up you push on it, the more leverage, but the less the other end moves. Move closer to the point you are prying with, the more it will move, but the less leverage you will have.
Lower right in pic
We are going to pull from bottom because the cable just happens to be lower than manifold..  It's funny you post those pictures as those were the pictures we have been working with to figure out what we need. Those pictures show parts numbers that also helped me find out there are kits being sold by my local Nissan dealer in stock ..
:thumbup: :thumbup:
From this thread ,, and "your shit" thread .
http://community.ratsun.net/topic/59502-prefferred-su-carbs-flat-or-dome/
Many drama queens criticize this place with every breath  but with a little research this place is a treasure for Datsun guys..
We have been lurking 720world quite a bit lately though.
:ninja: :ninja:
