TheEddie Posted May 10, 2014 Report Share Posted May 10, 2014 I didn't find this info using the "Search" function, sooooo... Anybody care to get me an Z20-24 engine lenght measurement, back of block (B/H face joint) to fan hub? Extra points for 720 usage! :thumbup: Eddie Quote Link to comment
Sealik Posted May 10, 2014 Report Share Posted May 10, 2014 23 3/4" from the back of the block to the outside of the clutch fan hub. That is for the Z22 and Z24....would assume the Z20 is of the same length. All were fitted in the 720 Quote Link to comment
TheEddie Posted May 10, 2014 Author Report Share Posted May 10, 2014 Close enuff, THANX Eddie Quote Link to comment
datzenmike Posted May 10, 2014 Report Share Posted May 10, 2014 Same as the L series blocks. 435 mm or 17 1/8" from back of block to the front block surface the timing cover fits onto. 63mm or 2.48" timing cover thickness to water pump mounting surface. 498mm or just under 19.5 " not counting the water pump and clutch fan. Sorry, I don't have one with the correct clutch fan on it. Quote Link to comment
ggzilla Posted May 10, 2014 Report Share Posted May 10, 2014 So L and Z engines are same length? Quote Link to comment
datzenmike Posted May 10, 2014 Report Share Posted May 10, 2014 I can compare L20B/Z24 to the one I posted for a Z22. They have some differences in height. Quote Link to comment
