COOCHaDAMus Posted April 15, 2014 Report Share Posted April 15, 2014 my 210 bros out there i need a lil help. 3rd & 4th gear went bye bye this past weekend. getting rebuild kits, if they even exist or are hard to find. if any of you knowledgeable back door masters on everything datsun parts. please tell me where-too's and where-a-bouts on getting parts for my lil japanese conveyance. looked on ebay & did craigslist yahoo japan isn't showing must promise either. any help would be the shit right now. Quote Link to comment
ggzilla Posted April 15, 2014 Report Share Posted April 15, 2014 Rebuild kit not needed. There are two bushings and four bearings. Nissan sells them. If 3rd & 4th went out, its probably just the shift mechanism. Just fix that. Which transmission do you have? There were three different ones for 1980. 1 Quote Link to comment
bananahamuck Posted April 15, 2014 Report Share Posted April 15, 2014 If nobody comes up with one ,, i'm pretty sure i know of a 4speed hidden in a back building at a yard in Hoquiam WA,, i am positive he will want $70. plus tax,, but it looks like it has been sitting a long time so not sure how drop in it will be, but if it becomes your last option i could caravan down with you and show you where it is.. And Hoquiam Wa is very far from you. Pumpkin210 or Slick Mcfavorate on facebook might know more local to you sources,, PM him. he is a really helpful guy ,,,, long winded,,,,,, but helpful none the less. 2 Quote Link to comment
COOCHaDAMus Posted April 16, 2014 Author Report Share Posted April 16, 2014 i HAD a 5 speed manual. i think that's what your asking. GG Quote Link to comment
ggzilla Posted April 16, 2014 Report Share Posted April 16, 2014 I was asking which transmission it is that you want to rebuild. There were three different manual transmissions used in 1980. If its a 4-speed just throw it away and replace with a good used one. About $40-$50 is the going rate. Quote Link to comment
COOCHaDAMus Posted April 16, 2014 Author Report Share Posted April 16, 2014 I was asking which transmission it is that you want to rebuild. There were three different manual transmissions used in 1980. If its a 4-speed just throw it away and replace with a good used one. About $40-$50 is the going rate. i want to rebuild the one that just went bad. i couldn't downgrade to a 4 speed. the one i have is a 5 speed manual. Quote Link to comment
ggzilla Posted April 16, 2014 Report Share Posted April 16, 2014 FSM has diagrams, assembly instructions and specifications. $15 from amazon. http://www.amazon.com/gp/aw/d/B000NDQA08 It covers the normal shift pattern 5-speed. The dogleg 5-speeds are from other years. 1 Quote Link to comment
COOCHaDAMus Posted April 17, 2014 Author Report Share Posted April 17, 2014 FSM has diagrams, assembly instructions and specifications. $15 from amazon. http://www.amazon.com/gp/aw/d/B000NDQA08 It covers the normal shift pattern 5-speed. The dogleg 5-speeds are from other years. GG aka gidderdone god. you are the man, man. thanks! Quote Link to comment
COOCHaDAMus Posted April 20, 2014 Author Report Share Posted April 20, 2014 FSM has diagrams, assembly instructions and specifications. $15 from amazon. http://www.amazon.com/gp/aw/d/B000NDQA08 It covers the normal shift pattern 5-speed. The dogleg 5-speeds are from other years. i order this book 10 bucks. Quote Link to comment
COOCHaDAMus Posted April 21, 2014 Author Report Share Posted April 21, 2014 Rebuild kit not needed. There are two bushings and four bearings. Nissan sells them. If 3rd & 4th went out, its probably just the shift mechanism. Just fix that. Which transmission do you have? There were three different ones for 1980. you called it right on the nose. took apart tranny the shift fork for 3rd & 4th was moving, but the rod its connected to wasn't. ta dah you are a life saver. 2 Quote Link to comment
bananahamuck Posted April 21, 2014 Report Share Posted April 21, 2014 So all those bad things i keep hearing about ggzilla aren't completely true. Quote Link to comment
ggzilla Posted April 21, 2014 Report Share Posted April 21, 2014 Nah, only some of them. Quote Link to comment
