freetheoranges Posted March 30, 2014 Report Share Posted March 30, 2014 Does the 1968 Datsun 510 Wiper Motor operate with a disk and two attachment assembly's? Is it mounted in the center of the engine bay or use longer assembly's? Are the 'arms' the same length (or separate; a shorter arm connected to a dual joint and longer arm) ? Tried to modify '69 assembly and failed... oics and discussion.. .. looking for that suicide (reverse) offset on the passenger blade, just not sure how to acquire it.. Quote Link to comment
Ranman72 Posted March 30, 2014 Report Share Posted March 30, 2014 68 wipers and motor are a breed of there own specific to 68 only and all different from 69 on Quote Link to comment
freetheoranges Posted March 30, 2014 Author Report Share Posted March 30, 2014 Thanks, Ranman! Yes I know they are in a field of their own... I feel like there is a similarity between the 68 510 and the 411 of some variety... I believe the 411 uses the same setup just shortened... any truth to that? I'm looking specifically for what the back of the motor looks like? Quote Link to comment
Ranman72 Posted March 30, 2014 Report Share Posted March 30, 2014 the back of the motor has a normal looking arm and rotates full circle I will try to find a pic its hard to explain how it works Quote Link to comment
That4doorKiD Posted January 2, 2016 Report Share Posted January 2, 2016 I only have the two wiper arms, and long linkage arms attached to them, so I am missing the whole center section. Missing, the plate, motor, and center link arm. Does the mazda conversion work on the 68? Is the center linkage arm replaceable with other datsun cars, roadsters, 411's? And is the plate interchangeable? Anyone know? Quote Link to comment
