dual SU vs triple makuni
oldgasman
  • Replies 4
Mikunis would definitely be the way to go for more power but youd also watch your fuel level steadily drop. what would you be putting them on?
^9 times out of 10, SU's would be a much better choice. Without a lot of headwork, cam, big valves, high compression, etc, it's usually not a very good idea. SU's are great carbs. Very easy to acquire, tune, and assemble. Z car SU's are 46mm (iirc) which is more then enough for even a relatively built motor on the street.
Now if you have money to burn..... you can't go wrong. Mikuni's sound amazing.
