620 on a 720 chassis???
67411sss
  • Replies 3
I have a '78 cab on an '82 2wd frame. Mounts all lined up. The 720 has a different steering box than the 620 so you will need to use a 720 column with collapsible spline, rag and U joint. Or something custom. '72 to '77 620 have the gas tank mounted to the underside of the box while all '78 and up 620s and all 720s the tank in mounted to the frame.
