speedometer pinion gear
russaroll
i'm swapping out the 4spd for a 5spd and i noticed that the gear that came out of the 4 is a bit shorter than the one that came with the 5.
will this make a difference?
could i just stuff the one out of my old 4spd into the 5spd?
  • Replies 2
Swap the Black gear to the other sleeve. You have to do this to keep your speedometer accurate anyway because going from an 18 Blue to a 17 tooth Red will make it read 3MPH faster @ 50. Just punch out that roll pin and the pinion pulls out
