H190 Locker or limited slip?
  • Replies 13
There was a Nissan Electro Anti-Lock on the Hardbody.
Yes, H190 EAL came on 2WD 4-cyl only. The 3rd member came in 3.545, 3.7 and 4.111 ratiios.
The 3.700 version came in 4-speed Hardbodies 1995 and early 1996.
Yes, that's the EAL sensor. It's the aluminum ring adapter behind the driveshaft flange (the wires are part of that).
bth_Pathfinder--D-21conversion012Large.j
classifieds-25973-0-98104100-1394160677.
ABS comes in many flavors and Nissan has used most of them, including 1-sensor ABS, 2-sensor ABS and 4-sensor ABS. EAL was the first Japanese system and fitted to the H190 in 1971. The 1967 Jensen FF was the first car to use ABS. A lot has happened in the last 50 years.
The good news it is LSD, and you can simply leave the wires unconnected to use it. It is the good clutch-pack type LSD, so can be rebuilt if it slips too much.
EXCEPT... it is not LSD but an open diff in your 2nd photo.
