L Series Motor Mounts
Wizeguy9999
Hi:
I'm building a 68 Datsun 510, and had a question.  The L-series that I'm putting in is well above the 90HP of the original L16.  I was curious if this would require better motor mounts than OEM equivalents.  If so, does anyone know where you can buy beefier L series motor mounts?
Thanks for the help!
  • Replies 5
Would an increase in weight matter then?  A 1.6 liter versus a 2+ liter engine?
Here is what I'm looking at:
(http://www.carparts.com/details/Nissan/510/Beck_Arnley/Motor_and_Transmission_Mount/1969/Base/4_Cyl_1-dot-6L/104-0827.html)
What generally concerns me (and maybe it shouldn't, and I should be happy and move on) is that these are so inexpensive versus upgraded motor mounts for installing like a KA (those seem to run like $100+).  It just seems odd that the motor mounts could be basically the same but the cost be so different.
