1983 Nissan datsun pick up one coil no spark
Roberto
I try to fined some help because my truck stop suddenly I change one of the coils because I notice that had no spark from the coil to the distribuitor and the other coil spark , I change the cable nothing happens , I Check for if it has voltage and it has , so if someone help me with this situation I wold be. Glad thank you
  • Replies 5
Some models of the dual plug engine shut the 2nd coil down to reduce noise. It is normal. But it should fire when idling or something like that.
The 2nd coil has its own fuse, so check the fuse box first.
  • 1 month later...
Thank you for your help the problem was the ignition control module . for my friends that try to find one o bought it from ebay at 55 dollars because in autozone the price was 333 dollars, just make sure that you order that right one
