720buck Posted February 16, 2014 Report Share Posted February 16, 2014 Hey. So this will sound a bit bizarre . I have ordered the same rear window, confirmed the make model and year ... twice... and have been given the wrong part.. BOTH times. Either one of two things: 1. I have really bad luck 2. Someone at the factory really likes to mislabel things. 3. (I am adding a third) The person labeling the parts with the sharpie is dyslexic. So to confirm, I was curious if ya'll have the..: 1980 Datsun 720 Kingcab part number for the rear sliding window. thanks Quote Link to comment
datzenmike Posted February 16, 2014 Report Share Posted February 16, 2014 Well I would check to see if the '80 even HAD a sliding rear window. My info shows only available from Oct '82 and on. The solid glass is different number before Oct. 82 also so unlikely the sliders sent to you will fit the earlier frame. Quote Link to comment
720buck Posted February 16, 2014 Author Report Share Posted February 16, 2014 Mine came with a sliding rear window. Trying to research it but not sure if that's a stock option or if it was just exclusively a sliding rear window. My research shows that all the 1980's had rear sliding windows but I am sure ya'll would be more knowledagle. Quote Link to comment
datzenmike Posted February 17, 2014 Report Share Posted February 17, 2014 Not saying that. Only that I can only find 10/'82 and on having them from the factory. Phone Nissan and ask directly about the 1980. Sometimes you have to lead the countermen around by the nose as you know more than they do. They probably weren't even born yet when your truck was new. The conversation may end like this... "Yeah the 720 had a slider rear window all years... Yeah I checked... Sure I'll look again but, oh.... well, what do you know? sez here... only from October '82 and on." Quote Link to comment
KELMO Posted February 22, 2014 Report Share Posted February 22, 2014 First question: On your slider, do you have 2 pieces of glass that slide or only 1? My catalog agrees with Mike (mostly) in that the application is from 11/82 and on. left slider: 79733-11W05 right slider: 79732-11W05 If you only have a single pane of glass that slides, it is either an aftermarket or possibly a Nissan Accessory slider. The unfortunate part about that is I do not have info on those. Wait, I remember a pic of your fix for that on here I think....I"ll be back OK, it looks like a double slider and I have no stinkin idea now. When I started doing Nissan parts the Hardbody had just come out and THAT accessory slider would have had only 1 slider. What you really need to find is someone that still has the microfiche with the accessory catalog....I know, chicken lips will be easier to find. By the way, what part #'s are they getting you? Will try and help where I can but no longer in the Nissan game. Went back and looked this up again and found that the part # is the same for both sides.....not sure how that is possible but...79732-11W05 is the part # for both Quote Link to comment
