r@+5un620 Posted February 16, 2014 Author Report Share Posted February 16, 2014 Ok quick update decided since an unexpected bill popped up to wait it out and after a week of driving i seem to have found a more narrowed down area from which i have a leak. in this second pic i can see what appears to be coolant sitting on top? Quote Link to comment
r@+5un620 Posted February 16, 2014 Author Report Share Posted February 16, 2014 i dont know how to even begin to take that off with there being bent steel lines and stuff on top of the bolts to get to this... Quote Link to comment
datzenmike Posted February 17, 2014 Report Share Posted February 17, 2014 Valve cover gasket? Try slightly tightening the valve cover bolts, but only wrist tight. Cover the distributor with a baggie and power wash the oily area clean. Carb spray works too. In a few days after driving and it has dried look for fresh oil. Quote Link to comment
smoke Posted February 17, 2014 Report Share Posted February 17, 2014 Also, unrelated, the vac hose to your distributor has a crack in it. Quote Link to comment
TENDRIL Posted February 17, 2014 Report Share Posted February 17, 2014 looks like its coming from your intake heat line , or that hose clamp Quote Link to comment
ggzilla Posted February 17, 2014 Report Share Posted February 17, 2014 >> in this second pic i can see what appears to be coolant sitting on top? > Valve cover gasket? Try slightly tightening the valve cover bolts Mike do you need some morning coffee? I can see the coolant pooling on top of the water pump. I agree its probably coming from the heater hose just above there. It looks like the hose might be the wrong size. Quote Link to comment
