Sealik Posted January 19, 2014 Report Share Posted January 19, 2014 What diameter is the intake port? And what kind of porting on the head. Did you increase size of the intake valves? I have an A87 with some work done. 1.5 intake with a peanut chamber that has been opened up. And the intake valves are increased to a 1.73in. I have been told that this head may not be worth doing anything with so not really sure yet. I matched the intake ports to the stock 1.5" gasket...head and K14 intake Stock valves Pulled intake to drill coolant ports in U67 head Looking through Sus...transitional (38-46) isolators....nice and smooth. Quote Link to comment
dr.feltersnatch Posted January 19, 2014 Report Share Posted January 19, 2014 i am running an l18 with sss 38mm flat tops and i love them. i have ran round tops in the past and i wouldnt choose one over the other. a bigger deciding factor between the two sets would be the throttle shafts. if one set is worn i would go to the other set. also another issue is the floats. see if they have been upgraded to the plastic ones. Quote Link to comment
ggzilla Posted January 19, 2014 Report Share Posted January 19, 2014 38mm Hitachi come in round top or flat top versions. Both are good. They do not need to be "de-smogged" which removes the fine idle mixture feature but it is commonly done. 46mm Hitachi comes in round top and flat top versions. They say the 46 flat tops don't work well. 38s are marginal for a 2 liter engine . They work excellent, but are a bit small. They were used on the L20B SSS in Europe. For high revving L20B use 46s. Quote Link to comment
Dantheman Posted January 19, 2014 Author Report Share Posted January 19, 2014 How does a 46mm fit to a 38mm manifold. I thought they have different mounting patterns. Quote Link to comment
Dantheman Posted January 20, 2014 Author Report Share Posted January 20, 2014 Makes sense. Do use the pre existing floats or use the whole z set up? Quote Link to comment
Sealik Posted January 20, 2014 Report Share Posted January 20, 2014 Used the floats that came with the Sus as they were in good shape. Shipped them off to get new bushings....new throttle plate and some linkage re-plated 46 Sus are larger than the 38s...sooooo the throttle bar has to be modified/shortened I started with a longer L6 bar....ended up with the piece on right in pic. Stock L4/38 bar in center Throttle cable pulls from bottom Quote Link to comment
Dantheman Posted January 20, 2014 Author Report Share Posted January 20, 2014 So this will require a little Work huh. I noticed you are running the stock exhaust manifold. No need for header with all that you have done? Does the heat shield interfere with a header? By the way thanks for all the advise, it is very much appreciated. Quote Link to comment
Son_of_a_Datsun_Guy Posted January 20, 2014 Report Share Posted January 20, 2014 Thanks for the input son_of_a_datsun_guy. The picture of your set up is clean. Your work or sent out to Ztheropy? My dad and I rebuilt them, but we used a Z-therapy kit. They make great quality stuff. Only problem I ran into was with my linkage, the previous owner messed with the order of the parts so it took me a few tries to get it working smoothly. Quote Link to comment
Sealik Posted January 20, 2014 Report Share Posted January 20, 2014 So this will require a little Work huh. I noticed you are running the stock exhaust manifold. No need for header with all that you have done? Does the heat shield interfere with a header? By the way thanks for all the advise, it is very much appreciated. Yup.....a bit of work...but well worth it. It's very satisfying to look back......and say......"hey!....I built that".... :thumbup: Pretty sure the stock exhaust will flow fine for my app. I designed my own heat shield somewhat based on this..... Out of a aluminum road construction sign... Quote Link to comment
Dantheman Posted January 20, 2014 Author Report Share Posted January 20, 2014 Awesome! Quote Link to comment
