EatLag Posted January 12, 2014 Report Share Posted January 12, 2014 Hey guys ATM my torsion bars are all the way down, how much could I unwind them before I throw the tires out and need to get a wheel alignment done? Quote Link to comment
Farmer Joe Posted January 13, 2014 Report Share Posted January 13, 2014 to go higher or lower? its a 4x4, right? Quote Link to comment
datzenmike Posted January 13, 2014 Report Share Posted January 13, 2014 The further up or down from the stock ride height the worse it will get. There is no set amount where it's wrong it just is or isn't. Drive straight ahead then line the front wheel side walls up with the tear tire side walls. Now go over to the pass side. If you can see the front tire pointing in (toe in) enough to notice it probably needs adjustment. Quote Link to comment
