620 fuel pump ?
76_620
  • Replies 3
Yes.
The following is from the '73 L16 620 and the '78 L20B 620 FSMs
Both should produce 1,000cc (1 liter) of fuel at 1,000 RPMs in one minute or less.
The L20B pump is 3 to 3.9 PSI
The L16 pump is 2.5 to 3 PSI.... more than enough for the Hitachi carb.
DO NOT BUY AN AIRTEX BRAND PUMP.
I made this mistake. Find out who manufactures the pump you're buying. The arm on mine decided it wanted to walk over off the lobe and ride up the washer.
No bueno for metal shavings and a truck that won't run.
I just had to replace mine last week for the same damn thing. Airtex is garbage.
