gryffinwings Posted January 3, 2014 Report Share Posted January 3, 2014 I need the fitting sizes that I need for coolant and oil pressure. These are Equus gauges I'm installing, that I've had for a while, just need a few things to install them. I was giving these specs for the coolant fittings: 9851 - Domestic and Asia -5/8 - 18 to 3/8 - 18 -1/4 - 18 -1/2 - 14 -m16 x 1.5 9852 - Asian Vehicles -5/8 - 18 to m16 x 1.5 For the oil, I'm not sure what I'm going to do because I want to keep the indicator functional. Any ideas for this. Thanks for any help provided. Quote Link to comment
DanielC Posted January 3, 2014 Report Share Posted January 3, 2014 For the oil pressure, you need to convert the block 1/8-27 ISO, or British thread to a 1/8-28 NPT thread. I think Edelmann 265220 is the adapter that will screw in to the block oil pressure hole, and it has a female 1/8-28 hole. One method, after putting the above adapter in the block is to put a 1/8 pipe "T", and then get a oil pressure switch with the American 1/8-28 thread, put that in one end of the "T", and then run the pressure sender, or pipe off the other side of the "T". I have done that oil pressure gauge addition. I have not added an aftermarket water temp gauge to a Datsun engine. I found it was easier to use the stock Datsun temp gauge. 1 Quote Link to comment
banzai510(hainz) Posted January 3, 2014 Report Share Posted January 3, 2014 Careful of those cheap Chinese plastic oil lines. buy ther autometer brand lines or get a newer type of guage that is electric sender type that plug in to the block. I went back to the stock sender myself as I had oil lines break, even a braided one. Lucky I caught this before I RAN OUT OF OIL. or use a Quality line. Dont be a cheap ass on this one!!!!!!!!!!!! keep a stock sender in glove box in case line goes bad and can plugg the hole and still make it home. I say buy a remote sender type. 2 Quote Link to comment
gryffinwings Posted January 4, 2014 Author Report Share Posted January 4, 2014 Careful of those cheap Chinese plastic oil lines. buy ther autometer brand lines or get a newer type of guage that is electric sender type that plug in to the block. I went back to the stock sender myself as I had oil lines break, even a braided one. Lucky I caught this before I RAN OUT OF OIL. or use a Quality line. Dont be a cheap ass on this one!!!!!!!!!!!! keep a stock sender in glove box in case line goes bad and can plugg the hole and still make it home. I say buy a remote sender type. Thanks for the warning, I never considered that, do you have specific recommendations on an inexpensive 2" unit? I think I will likely tee off the oil pressure sender, so I can have the indicator and the gauge. Quote Link to comment
banzai510(hainz) Posted January 4, 2014 Report Share Posted January 4, 2014 T off is good. A specifc brand line I say look at Autometer. brand of gauges. Autometer the USA ones are good but I have one I got from a junkyard and is very good. I have a a Steward Warner in my truck, The bigger the line the faster the response. If I had to use a oil line I would get a braided one. Plastic gets hot /cold and over time gets brittle. Quote Link to comment
banzai510(hainz) Posted January 4, 2014 Report Share Posted January 4, 2014 just to let you know a stock 200mm510/521 is 350 KG Roadster 650KG 620 225mm 450KG 620 225mm Daiken stage 1 750KG( i believe not positive) 350kg+60%= 560kg just questtion them. I seen Roadster clutches sold(O rillys but really were stock 510/521 as the have the same diaphrame height,same part number Quote Link to comment
gryffinwings Posted January 6, 2014 Author Report Share Posted January 6, 2014 Well I figured out what I'm going to do for the temperature gauge. Found this on Summit Racing website. http://www.summitracing.com/parts/mio-mmwhs-32-bk?seid=srese1&gclid=CIr5uP7Z6LsCFStBQgodblMAhA Mishimoto Water Temperature Sensor Adapter: Quote Link to comment
