DatsunSwag22 Posted December 30, 2013 Report Share Posted December 30, 2013 i have a 71 datsun 510 2 door, not a 100% if wired right. i get it to turn over but no spark. please help me Quote Link to comment
DatsunSwag22 Posted December 30, 2013 Author Report Share Posted December 30, 2013 i followed the diagrams I've got from other but i don't think its right. i have power at everything. coil is getting really hot. i don't think that is normal. please help Quote Link to comment
Icehouse Posted December 30, 2013 Report Share Posted December 30, 2013 Post the diagram you followed then we will know if it's wired right. Quote Link to comment
DatsunSwag22 Posted December 30, 2013 Author Report Share Posted December 30, 2013 Post the diagram you followed then we will know if it's wired right. Idk how to post a pic ! It's the diagram from the can/am post. Quote Link to comment
datzenmike Posted December 30, 2013 Report Share Posted December 30, 2013 http://community.ratsun.net/topic/691-how-to-post-pictures-and-keep-online-photo-albums/ Quote Link to comment
DatsunSwag22 Posted December 30, 2013 Author Report Share Posted December 30, 2013 http://s1217.photobucket.com/user/datsunswag22/library/Mobile%20Uploads Quote Link to comment
DatsunSwag22 Posted December 30, 2013 Author Report Share Posted December 30, 2013 http://s1217.photobucket.com/user/datsunswag22/media/Mobile%20Uploads/image.jpg.html?sort=3&o=0 Quote Link to comment
Icehouse Posted December 31, 2013 Report Share Posted December 31, 2013 Still no spark? The coil should not be really hot. 1 Quote Link to comment
DatsunSwag22 Posted December 31, 2013 Author Report Share Posted December 31, 2013 No spark at all! I'm goin crazy Quote Link to comment
datzenmike Posted December 31, 2013 Report Share Posted December 31, 2013 Hot coil means power is flowing through it all the time. If there is cranking it should have on off on off pulses. The EI ignitions are such that if the key is left ON and there is no cranking the power to the coil is temp turned off to prevent over heating. Quote Link to comment
Icehouse Posted December 31, 2013 Report Share Posted December 31, 2013 Since the ecu triggers the coil pulse it could be a few different things. The ecu should send out a logic level output to the ignition transistor which is located next to the coil. Is the ignition transistor also getting hot? Do the wires around the coil and transistor look tampered with? What about the engine. Did you see it run before buying it? Do you have the correct ecu? Quote Link to comment
jesusno2 Posted December 31, 2013 Report Share Posted December 31, 2013 Oh yea I forgot about the ignitor or ignition module what ever you call it I had one of those just randomly die in traffic on me once. Quote Link to comment
DatsunSwag22 Posted December 31, 2013 Author Report Share Posted December 31, 2013 Just the coil! Motor was running it was in a homies car we pulled n put in the same day ! Ecu is the right one n the wires look tampered but it should work if I didn't fuk wit any of those bit the inside ones Quote Link to comment
