scottfelsen Posted December 25, 2013 Report Share Posted December 25, 2013 I have a 1982 Diesel 720 long bed. The original truck bed is so rusted I want to replace it. Does any one know what will fit on the truck? Can I get a truck bed from a different truck like a Toyota perhaps? has anyone ever done this before? Any advise would be appreciated. Quote Link to comment
DaveZilla Posted December 25, 2013 Report Share Posted December 25, 2013 I'm thinking the newer 720 beds are just different enough that they won't fit without doing some mods... I don't know anything about trying to swap to a non Nissan bed but most likely you'll have to do some mods to make it fit... You could always convert yours to a flatbed which would be just about as easy... Quote Link to comment
wayno Posted December 25, 2013 Report Share Posted December 25, 2013 A newer Nissan longbed will not fit, you have to have a 1980-82 longbed for it to fit, the later longbeds are about 3 inches shorter, as the later cabs are 3 inches longer. As for other beds fitting you truck, you just have to go to the wrecking yards with a tape measure and start looking around, the problem with that is the body lines will not match, and it will likely look like it doesn't belong on there. Quote Link to comment
datzenmike Posted December 25, 2013 Report Share Posted December 25, 2013 Best would be an '80-'82 long bed box from another 720. The '83 and up long beds (are very slightly different dimensionally) and have the tail lights in the upper back corners of the box. I dare say that one could fit a later 720 long bed box and graft the wiring to make it work. A Toyota box might fit if long enough. I doubt the frame mounting bolts would line up nor the wiring match in any way nor the wheel well fit exactly. All 720s have the same gas tank location on the frame, so there's another plus for a 720 box. Quote Link to comment
scottfelsen Posted December 26, 2013 Author Report Share Posted December 26, 2013 Thanks for the information. I will have to start looking around. I think if I sand blasted the current truck bed, I would be missing half of it!!! I will see if I can find a better preserved one off a 720. Otherwise I will have to fix this one. That will be hard!!! lol Quote Link to comment
datzenmike Posted December 26, 2013 Report Share Posted December 26, 2013 The '80-'84 bed has a horizontal seam that was rust prone. The '85-'86 had one piece sides and much better. The later one is not a direct drop on fit. There were three bed type on the 720, all with some differences. Quote Link to comment
wayno Posted December 27, 2013 Report Share Posted December 27, 2013 Thanks for the information. I will have to start looking around. I think if I sand blasted the current truck bed, I would be missing half of it!!! I will see if I can find a better preserved one off a 720. Otherwise I will have to fix this one. That will be hard!!! lol You need a longbox from a 1980-82 only, 83 plus will leave you with a 3 or 4 inch gap between the cab and front of box. There is a thread on Ratsun about this, titled something like, "it was an expensive mistake". Here is a link to the thread, you should read it. https://www.google.com/url?q=http://community.ratsun.net/topic/58156-how-i-learned-bout-short-early-datsun-720-cabs/&sa=U&ei=mM68UqPfI5TfoASo9ICQBA&ved=0CAoQFjAC&client=internal-uds-cse&usg=AFQjCNE_j0dGfCKxfLZpfi3LgTPkdx9ENA Quote Link to comment
scottfelsen Posted December 28, 2013 Author Report Share Posted December 28, 2013 Thank you. I did read the thread and I appreciate all your help... Maybe I will just have to replace all the rust on the one I have.... Its a ton of work, but it may be easier then finding a good long bed... Quote Link to comment
Bandit240 Posted December 30, 2013 Report Share Posted December 30, 2013 How about on a king cab? I've got a 1980 KC and I have considered swapping the bed for the later model for the added safety of the tail lights being mounted on the side. Quote Link to comment
datzenmike Posted December 30, 2013 Report Share Posted December 30, 2013 I think the same reason. The '83 and up had an enlarged cab, thus the bed was shortened slightly. The shortened KC bed will leave a gap on your '80. Maybe get a tape measure and mark the overall length and from the cab back to the center of the wheel well. Quote Link to comment
