guyster Posted December 3, 2013 Report Share Posted December 3, 2013 I'm looking for a 2" rear drop and recall that I need a 2" wide block (for leaf stack). I also understand that the shackles (U bolts) for my axle are smaller than what comes with universal kits. Can someone please straighten me out if I'm wrong on these two points... or better yet, post a couple links to the lowering kit that I require. Gracie! Quote Link to comment
Ratty260z Posted December 3, 2013 Report Share Posted December 3, 2013 Measure the U-bolts you have, order some 2" blocks and the size u-bolts you need and BAM there ya go, from the picture it looks like you got the RHD 120y that was on the colorado craigslist, is it as nice as it looked? Quote Link to comment
izzo Posted December 3, 2013 Report Share Posted December 3, 2013 wouldn't you be able to find this info on belltech or jegs? Quote Link to comment
izzo Posted December 3, 2013 Report Share Posted December 3, 2013 give this a read also. http://datsun1200.com/modules/mediawiki/index.php?title=Lowering_Blocks Quote Link to comment
0r0B210 Posted December 4, 2013 Report Share Posted December 4, 2013 Measure the U-bolts you have, order some 2" blocks and the size u-bolts you need and BAM there ya go, from the picture it looks like you got the RHD 120y that was on the colorado craigslist, is it as nice as it looked? This is the fastest, cheapest, and easiest way to lower the rear. Quote Link to comment
ggzilla Posted December 4, 2013 Report Share Posted December 4, 2013 Too bad no one sells a lowering block kit specific to the B210. Quote Link to comment
Bentaxlebob Posted December 4, 2013 Report Share Posted December 4, 2013 Decambering your springs is the easiest way. Blocks allow you to do it in a fast manner (procided you have the long U bolts that fit your axle and spring), but as said before, need additional parts. Also blocks, although looking good, sometimes slide. It also lowers the rear springs away from car and closer to floor/road. Decambering allows you to use all your stock U bolts and parts. The spring and axle remain in same position relative to each other. No issues with sliding parts. Got to remove the leaf springs and take them to a shop for decambering, that could set you back 2 days or so. Unless the shop could do it same day. Think about it. Straight leaves are also better performance wise. Choice of racers. Quote Link to comment
guyster Posted December 4, 2013 Author Report Share Posted December 4, 2013 Thanks for this guidance. I thought it would be possible to just buy a kit, but obvs that's not poss. Yes, this is the car out of Colorado. It is great! It has been nicely resprayed, the interior is impeccable, needed a new exhaust, and has minor rust on inner engine well by steering box and lower shock tower. The price was great, but shipping and tax added 25%. Measure the U-bolts you have, order some 2" blocks and the size u-bolts you need and BAM there ya go, from the picture it looks like you got the RHD 120y that was on the colorado craigslist, is it as nice as it looked? Quote Link to comment
guyster Posted December 4, 2013 Author Report Share Posted December 4, 2013 Decambering your springs is the easiest way. Blocks allow you to do it in a fast manner (procided you have the long U bolts that fit your axle and spring), but as said before, need additional parts. Also blocks, although looking good, sometimes slide. It also lowers the rear springs away from car and closer to floor/road. Decambering allows you to use all your stock U bolts and parts. The spring and axle remain in same position relative to each other. No issues with sliding parts. Got to remove the leaf springs and take them to a shop for decambering, that could set you back 2 days or so. Unless the shop could do it same day. Think about it. Straight leaves are also better performance wise. Choice of racers. Very interesting idea. I hadn't seen this as an option in the tech wiki that I recall. Maybe I just ignored it. Quote Link to comment
guyster Posted December 4, 2013 Author Report Share Posted December 4, 2013 Too bad no one sells a lowering block kit specific to the B210. That's what I was looking for by posting my question. Thanks for confirming this. I thought I was going crazy! Quote Link to comment
guyster Posted December 4, 2013 Author Report Share Posted December 4, 2013 Measure the U-bolts you have, order some 2" blocks and the size u-bolts you need and BAM there ya go, from the picture it looks like you got the RHD 120y that was on the colorado craigslist, is it as nice as it looked? So far, every block I research is either 2 3/8" wide or 2 1/2" wide. Will these work? I thought I read that the block should be 2" wide. Quote Link to comment
ggzilla Posted December 4, 2013 Report Share Posted December 4, 2013 Measure it, and let us know. The ubolts hang down so are easy to access from the bottom Measure the distance between to see if 2-3/8 will fit. Quote Link to comment
guyster Posted December 4, 2013 Author Report Share Posted December 4, 2013 Measure it, and let us know. The ubolts hang down so are easy to access from the bottom Measure the distance between to see if 2-3/8 will fit. Will do. You've caught me being very lazy and trying to do all my mods from my desk at work. Sometimes, one just has to get under the car! Hahahhaha! I will measure and post my results. Quote Link to comment
