73DATSON Posted December 2, 2013 Report Share Posted December 2, 2013 Does anybody have a diagram for the factory tech? I just got a white needle one with four wires? And I was told its for 70-73 510? It does fit perfect:-) Quote Link to comment
73DATSON Posted December 2, 2013 Author Report Share Posted December 2, 2013 Lol yes tachometer , RPM.... Quote Link to comment
datzenmike Posted December 2, 2013 Report Share Posted December 2, 2013 Usually if there is any option, the wiring for it is already there on the harness. If so, it will be taped up an look like a bulge wrapped in electrical tape and will generally be near where it's needed and will reach. You may have to carefully slit the electrical tape to expose it. 1/ Black........... ground 2/ Green.......... +12 The other two White wires must be connected in series between the negative coil terminal and the points. In other words when the points close current is drawn from the coil, through the tach and to ground through the points. 3/ White........... coil negative terminal 4/ White........... wire going to the points. If the tach does not read or not properly, reverse these two White wires. Quote Link to comment
73DATSON Posted December 2, 2013 Author Report Share Posted December 2, 2013 DUDE I LOVE THESE FORUM!!!! THX....:-)) Quote Link to comment
datzenmike Posted December 2, 2013 Report Share Posted December 2, 2013 No homo, but we love you too. Let me know if the factory harness has the plug there tapped up or not. Quote Link to comment
