braveops Posted October 27, 2013 Report Share Posted October 27, 2013 i got a chance to get a single cam ka24 from h/b that was put in a old 4x4 so the pan has been hacked up is it worth it for me to pick it up for my 510? what pan can i use? trying to find some pics of pans so i can see the diffrence Quote Link to comment
datzenmike Posted October 27, 2013 Report Share Posted October 27, 2013 Top pan in both pictures is from a KA24E S13 (240sx) motor. Bottom is a KA24E motor from a D21. As you can see the sump and oil pick up are at the front and allow a car steering linkage to clear the back. The front may still not clear a 510 car crossmember so you may have to cut and flip the crossmember and weld it back up. The S13 motor has a crank girdle and so is deeper in the shallow part for clearance. The trucks didn't get this. But that's ok, a car pan will fit the truck block just not the other way around. You will need the car KA's oil pick up tube. Quote Link to comment
flatcat19 Posted October 27, 2013 Report Share Posted October 27, 2013 Your life would be easier had it been a 240sx motor. Depending on price is really the Should I, should I not factor. What's the condition of motor? Does it run? Quote Link to comment
datzenmike Posted October 27, 2013 Report Share Posted October 27, 2013 The D21 is much lighter than the S13 motor, but I like the looks of the S13 EFI better. Quote Link to comment
flatcat19 Posted October 27, 2013 Report Share Posted October 27, 2013 Wiring up the ECU is less painful for a 240x than a D21. Quote Link to comment
braveops Posted October 28, 2013 Author Report Share Posted October 28, 2013 well it does have sx manifold on it i think has 120kms and is complete with harness ecu but no tranny for 100 bucks or 50 if i take whole 720 4x4. not sure on the pots and pan pic thou... lol but on the plus side i did get eaton m62 :) Quote Link to comment
flatcat19 Posted October 28, 2013 Report Share Posted October 28, 2013 Meh. Pull the trigger. Everything is worth more than that in parts alone. Quote Link to comment
datzenmike Posted October 28, 2013 Report Share Posted October 28, 2013 well it does have sx manifold on it i think has 120kms and is complete with harness ecu but no tranny for 100 bucks or 50 if i take whole 720 4x4. not sure on the pots and pan pic thou... lol but on the plus side i did get eaton m62 :) . MMmmm...... eaton Quote Link to comment
flatcat19 Posted October 28, 2013 Report Share Posted October 28, 2013 www.ka24der.com Quote Link to comment
Farmer Joe Posted October 28, 2013 Report Share Posted October 28, 2013 so its a single cam KA from a HB/D21, with a 240sx intake already installed, and it ran like this? what was it pulled out of? if its the truck engine, its got the rear-rear sump. a stock 510 oil pan from an l16 is kind of a middle sump really.. then the s13 KAs have the obvious front-front sump. fitting the truck KA in the 510 chassis would probably work, if it didnt have the steering installed, or it had a rack or something. cut an L-series pan up, and the stock truck pan, and make a mid sump KA pan... eh? eh? Quote Link to comment
braveops Posted October 28, 2013 Author Report Share Posted October 28, 2013 it does run or did for 6 months of driving from what they told me.i hopefully will pick it up soon as he gets it out. the pan has been hacked up to fit a 720 4x4 so i have to start all over on that one Quote Link to comment
dime'n daily Posted November 1, 2013 Report Share Posted November 1, 2013 I have one sitting in my garage for my brothers 720, but was thinking the same thing for my 510 we also got an intake mani from s13 for it let me know how it goes, still on the lookout for a s13 one though Quote Link to comment
braveops Posted November 10, 2013 Author Report Share Posted November 10, 2013 well at the rate i am going it could be quite awhile.i still have not got my 24de in yet still working on mounts and rear sump for it :crying: :crying: Quote Link to comment
