datzenmike Posted October 18, 2013 Report Share Posted October 18, 2013 Cold adjustments assume that the motor will warm up to the correct lash. If the motor is already hot it can't be wrong. Cold would be fine for setting an initial lash on assembly. Hot checking assures it is correct when running. Quote Link to comment
jacobryandavidson Posted October 18, 2013 Author Report Share Posted October 18, 2013 okay guys I got the head on it last night and I'm driving it right now but all of a sudden loss letting it idle around every one of my gauages just quit working except my speedomet? Quote Link to comment
EricJB Posted October 18, 2013 Report Share Posted October 18, 2013 Don't forget, with NGK and only NGK, the lower the #, the hotter the plug. A 5 is hotter than a 6. Bosch is the opposite. Check your ground connection from the body to the battery. Quote Link to comment
jacobryandavidson Posted October 18, 2013 Author Report Share Posted October 18, 2013 well autozone owned up to it and gave me the most expensive plugs that they have and I'm an idiot it had a bad fuse that I thought I'd checked Quote Link to comment
jacobryandavidson Posted October 18, 2013 Author Report Share Posted October 18, 2013 it started knocking around 3000 rpm and then when you let off the gas going down the highway Quote Link to comment
datzenmike Posted October 19, 2013 Report Share Posted October 19, 2013 What are all those metal filings on the top of the valve spring??? How did the piston look on the cylinder with the hole above it??? Knocking? Did you check the oil? Quote Link to comment
jacobryandavidson Posted October 19, 2013 Author Report Share Posted October 19, 2013 I know it looks like metal shavings but its White Rock from our driveway and the number one piston was scarred up yes and that developed a pretty bad knock but I can sit here and rap eight grand and it won't blow so I don't know what's that thing it only does it around 3000 rpm and when I let off the gas Quote Link to comment
datzenmike Posted October 19, 2013 Report Share Posted October 19, 2013 Exhaust pipe rattling against something? Quote Link to comment
jacobryandavidson Posted October 20, 2013 Author Report Share Posted October 20, 2013 Def detenation caused this Quote Link to comment
datzenmike Posted October 20, 2013 Report Share Posted October 20, 2013 Not necessarily. My old 521s were worn into the copper too just from old age/wear. What's the crank journal look like? If within spec you can just replace the bearings. I'd do all of them as you have it apart anyway. Quote Link to comment
jacobryandavidson Posted October 20, 2013 Author Report Share Posted October 20, 2013 Crank was fine i put new bearings still knocking :( im thinking piston slap or timing chain? Quote Link to comment
datzenmike Posted October 20, 2013 Report Share Posted October 20, 2013 Timing chain doesn't know if full or part throttle, it just turns. Does the 'knocking' come and go with the throttle? Louder with heavy throttle??? What did the other bearings look like? If also worn did you check the mains? Quote Link to comment
jacobryandavidson Posted October 21, 2013 Author Report Share Posted October 21, 2013 Around 3k rpms starts and goes away under load Quote Link to comment
jacobryandavidson Posted October 21, 2013 Author Report Share Posted October 21, 2013 where are the oil pumps on the things Quote Link to comment
