CappsDaddy Posted October 4, 2013 Report Share Posted October 4, 2013 Does anyone know where I can get a Weber carb rebuild kit in the Stockton area? Also, does anyone in the area have any experience adjusting these carbs? Quote Link to comment
KlassicMotion Posted October 4, 2013 Report Share Posted October 4, 2013 Which Weber carb are you talking about? You can find parts here: http://www.webercarbsdirect.com/ How to tune here: click on tech info http://www.redlineweber.com/ 1 Quote Link to comment
Stoffregen Motorsports Posted October 5, 2013 Report Share Posted October 5, 2013 Troy Ermish is in Tracy. Not too far. Quote Link to comment
CappsDaddy Posted October 5, 2013 Author Report Share Posted October 5, 2013 It's a 32/36 on an L20B. Having idle/running issues. Dizzy seems to have been installed wrong. At least 1-2 teeth off. I'm new to this working on stuff myself so I'm not sure how to fix it. Symptoms include not wanting to idle unless on the throttle and massive popping from the carb while driving along with raw fuelsmell. No fuel leaks aanywhere, so I know its also from the carb. Quote Link to comment
banzai510(hainz) Posted October 5, 2013 Report Share Posted October 5, 2013 Its simple dial motor to TDC and see where your rotorpoints to. Set the dizzy to center of adjustment. If off drop the oil pump then reinsert till its at #1 plug wire. start then do s slight readjustment on dizzy. Usually adj the dizzy to 7-12 depending on motor and resetthe mixture till it sings to you http://www.youtube.com/watch?v=_aBTjhJMByo&list=PL8EF51386855F2B58&index=6 or watch all the vid from begining Quote Link to comment
KlassicMotion Posted October 5, 2013 Report Share Posted October 5, 2013 The video is good. Here is more ammunition: I pulled this from another thread: -------- This is how to get your distributor lined up in the correct spot: (This was just posted in another thread I'm watching) I put a matchbox on the engine that came in Dragon 2 today. It is a L-18, and has different timing marks, but the theory is the same. First, when assembling an engine, TDC #1 is important. But the engine does not fire at TDC. It fires before that. This method works for me. When installing a distributor, you need to turn the engine to the point the engine fires, not TDC. I set the engine about 12 degrees before TDC. When I did that, this is where the drive spindle for the distributor ended up. And when I put the matchbox distributor on, I had the same problem you had. The rotor pointed between 2 and 4, like yours. The solution is to drop the oil pump, and reindex the distributor drive spindle. This is how to reindex the drive spindle. Put the distributor on the engine, it does not matter for now where the rotor points we will change that. Center both adjustments on the distributor clocking plate. With the distributor on the engine decide on where Number one spark plug wire will be. I chose this one. Make a mark on the distributor body below number one tower. This is where you want the rotor to point, eventually. Take the distributor off the engine, and turn the rotor to point at the mark you made. Carefully look at the bottom of the distributor drive slot, and see how it is oriented, and that will be the new position of the oil pump drive spindle. Take the four bolts out of the oil pump, and drop it out of the engine, with the spindle. Turn the spindle, in the oil pump to the new position. Oil will come out of the pump. Slide the drive spindle back up into the front cover, and see if it will line up on the distributor, with the rotor pointing at number one tower. You may have to make a few tries to get it to line up properly. My spindle ended up like this, with the engine at 12 degrees before TDC. After I did all that, the distributor rotor points to the tower in the above picture, with my finger, with the spikes in the distributor lined up exactly, and the engine at 12 before TDC. If you look straight down the electrical connector, the vertical leg of the "T" is the "B" terminal. it has the thicker wire. The top of the "T" is the "C" terminal. Quote Link to comment
