Justin Tawney Posted October 3, 2013 Report Share Posted October 3, 2013 so. might be a noob question. but to change a timing chain do you have to remove the engine, I took the radiater out and seems like I can work on it pretty well. but I just cant get the timing chain cover to come off. I got all the bolts removed and distributor removed also. Quote Link to comment
Laecaon Posted October 3, 2013 Report Share Posted October 3, 2013 Oil pump needs to be removed. water pump has a bolt that goes into the block. There is a bolt behind the oil pump. 2 bolts from the head to the timing cover. It will need to be nudged forward with a mallet. Quote Link to comment
Justin Tawney Posted October 3, 2013 Author Report Share Posted October 3, 2013 thanks I got it. didn't realize that a few of the oil pan bolts needed to be removed, and the previous owner who "rebuilt" the engine didn't know what he was doing I don't think. the right said of the timing chain was really loose. and was not adjusted right at all when he said the engine was running because the carb needed to be rebuilt. I didn't know I was buying such a project. was hoping it was just the carb I should hav e it running in a few days. Quote Link to comment
datzenmike Posted October 3, 2013 Report Share Posted October 3, 2013 The right side will have some slack in it, that's normal. The chain tensioner keeps is somewhat snug. The timing cover has two small dowel pins to align it so for the first 1/4" it has to come straight out from the block. Loosen the oil pan bolts about half way down each side so the pan is loose at the front and you may get it off without ripping the pan gasket. The head gasket isn't as critical as it only seals in fumes and oil spray from the cam.Before ripping the timing cover off set motor to TDC accurately. Now look through the top hole in the cam sprocket. You should see this. A small U or V shape notch in the back of the sprocket. It should line up with a corresponding small horizontal etch line in the cam thrust plate just above and behind it. Properly installed and timed, the U or V should be just below or very slightly to the right of the line. This one is perfect and needs no adjustment or replacement. Check yours first and save yourself some bother. Cam thrust plate. Quote Link to comment
banzai510(hainz) Posted October 3, 2013 Report Share Posted October 3, 2013 you can lower the il pan to help get the front cover off. to prevent ripping the pan gasket if ripped cut another one and rtv and splice it in after you get the front cover off. as for thr right side loose? it wont be loose if the yourn the motor clockwise. loose will be on the left side. watch this 20 times. soem slight nomanclature wrrors and suck but I didnt have a script. watch and listen carefully on hoew to set heap up before removal to line up TDC before removal of front cover. Quote Link to comment
Justin Tawney Posted October 4, 2013 Author Report Share Posted October 4, 2013 k got my car to run for a bit but it doesn't stay running it abruptly stops after being on for a a couple seconds. Quote Link to comment
banzai510(hainz) Posted October 4, 2013 Report Share Posted October 4, 2013 adjust the carb mixture and distributor. Quote Link to comment
Justin Tawney Posted October 5, 2013 Author Report Share Posted October 5, 2013 after a couple of weeks. I finally got it running and driving!!! Quote Link to comment
