91hrdbdy Posted August 8, 2013 Report Share Posted August 8, 2013 so i bought this truck and i totally love it. but the other day i was sitting in traffic and the fuse panel got kinda warm. i could smell hot wires. so i got home and started prodding around and well it was a fire waiting to happen bare hot leads 1000.00 bucks worth or electrical tape wrapping a rat nest of wires so i decided to remove the dash and well it just got worse. no grommets. it was really bad. well i removed all the wiring and did as little cutting as possible so here is where i'm at i have no wiring in my truck. except for the taillight harness. how do i go about doing this properly. should i wire the truck back to factory and then add the motor wiring (i just got the can/am box form icehouse) or should i run a new harness for the truck from painless. I would be willing to pay someone in the SF valley to come over for a afternoon and help me out with this. im not a wire guy. Quote Link to comment
]2eDeYe Posted August 8, 2013 Report Share Posted August 8, 2013 I personally prefer swapped motors to be a separate harness. I also try to make it as easy as possible to go back to the original drivetrain, but that is not really difficult even if the harness is stripped. Quote Link to comment
91hrdbdy Posted August 8, 2013 Author Report Share Posted August 8, 2013 that what i was thinking i should do just fix the factory harness make it work like it was supposed one i get that done then add the engine harness on a completely separate system. Quote Link to comment
91hrdbdy Posted August 14, 2013 Author Report Share Posted August 14, 2013 so after some thought and finding out my 74 620 had a 78 harness in it i went ahead a rewired the whole thing cab forward. I run a shop here in Simi Valley specializing in GM G-bodys and i stock a 21 circut harness that is a direct replacement for the 78-88 malibu / elcamino. so i went head and pull one off the shelf and started my install. i will be using all the Datsun plugs so i can keep all my dash accessories. and factory turn signal. here are some pics. here is what i started with all the wiring was just stuffed in the corner inside was not much better found a lot of stuff like this starting to place the fuse box I ran all the circuts in there own loom so it will be easy to track wiring down later on going to be placing a rubber pass through grommet at the firewall when i come in(fri) around the front all in a nice loom my fuel pump/fan relay box Quote Link to comment
91hrdbdy Posted August 23, 2013 Author Report Share Posted August 23, 2013 here is a little update. ive got the fuse block mounted and ive got functions tail light turn signals and flashers. im waiting on finding a wiper switch to hook that up. ive got the computer mounted under the dash. now here is where my questions begin Ive got the can am box and i need some help hooking up the ecm to the motor. i have these wiring harness left im not sure if i have to use all this stuff ( ive never done a efi system) i know one is for my motor but the other ones im not sure why i would need them if i replaced the entire trucks harness. Quote Link to comment
91hrdbdy Posted October 1, 2013 Author Report Share Posted October 1, 2013 do i did a complete rewire of the truck it was a nightmare of a wiring job. i got it all installed and i go to start it up last night it started right up but idles like it has a vacuum leak its running super rich and if i rev it up it acts like its bouncing off a rev limiter. I did a little research and someone said knock sensor. so i check that plug it is plugged in (this truck ran before i redid the wiring.) i unplugged the maf while the truck was running and no change. so am i thinking its must me something in the wiring of the maf? any one have these symptoms before? Quote Link to comment
datzenmike Posted October 1, 2013 Report Share Posted October 1, 2013 You already have a post on the wiring .. http://community.ratsun.net/topic/57055-620-ka24de-wiring-nightmare/ What I've done is merged it with this one. If you have more woring experiences keep them all together in this thread. Quote Link to comment
