datsol b210 Posted September 30, 2013 Report Share Posted September 30, 2013 how should I start after buying the coilovers? it says I need to weld, what do I need to weld/? Quote Link to comment
graveltrapp Posted September 30, 2013 Report Share Posted September 30, 2013 No weld, buy split collars, allow for more tweaking and adjustment. 1 Quote Link to comment
datsol b210 Posted October 1, 2013 Author Report Share Posted October 1, 2013 explain please Quote Link to comment
datsunfreak Posted October 28, 2013 Report Share Posted October 28, 2013 how should I start after buying the coilovers? it says I need to weld, what do I need to weld/? It will come with metal rings that after cutting off the stock spring perch you will weld to the strut tube. Weld-on ring looks like this: http://i115.photobucket.com/albums/n311/fast_eddie_72/DSCF3465.jpg No weld, buy split collars, allow for more tweaking and adjustment. explain please Split collar replaces the weld-on ring. Looks like this: http://ecx.images-amazon.com/images/I/41Vv28dohqL._SL500_AA300_.jpg Allows you to mount the sleeve at almost any height you want, at any time you want, instead of just one permanent spot like the weld-on. Quote Link to comment
datsunfreak Posted October 28, 2013 Report Share Posted October 28, 2013 Split collar installed... Regular ring installed... 1 Quote Link to comment
