thistrapper91 Posted September 18, 2013 Report Share Posted September 18, 2013 I have been snooping on this site for a while and finally decided to start an account. I have a 1979 620 pickup with the l20 and 5speed. I want to convert it to 4wd. Not for hard wheeling, but just to be able to get around better on ice in the winter. I have a pair of axels off of a 90 jeep wrangler and was wondering what I need next? At first I was thinking of going the d20 route, but what do I need to make this work behind my tranny? And after that step, does anybody have recommendations for where to find leaf springs to put up front and keep a 'close to stock' height? Thanks ahead of time!!! Quote Link to comment
datzenmike Posted September 18, 2013 Report Share Posted September 18, 2013 Probably easier to swap the body onto an old Toyota 4x4 or a 720 with IFS. If going with Jeep axles you still need a transfer case. I used the divorced T-100 trans case from a 720 but it doesn't clear the 620 torsion bar cross member. (you really need a 4x4 frame from a 720). I put a Toyota front axle in my 620 but the steering was a nightmare. I converted to power steering because of the effort to turn the tires. I would advise finding a 720 4X4 and swap the body. Quote Link to comment
]2eDeYe Posted September 18, 2013 Report Share Posted September 18, 2013 The axles in that wrangler are just about the weakest ever put in a Jeep. Just an FYI. Easiest transfer case option is a divorced case. You can get any number of t-cases this way including the Dana 20. You will need to get an intermediated drive shaft made to go between the t-case and transmission and then drive shafts built to mate up the t-case to your axles. You can use the springs from that wrangler if you have access to them or use stock wagoneer springs. Pretty much want a flatish spring to keep the height down. Sounds like a trip or 2 to pull a part with a tape measure are in order. :) Quote Link to comment
