L16 with pertronix, which coil to use?
reese
I have an stock l16 and I want to buy a pertronix 1741 electronic ignition conversion. Do I use a 1.5 ohm coil and keep the ballast resistor. My last car with l16 had a pertronix on it with a 3.0 ohm coil and the ballast removed. Which is correct?
Thanks,
Erik in NE Portland
  • Replies 3
both ways are correct
I personally use the ballast resistor because my coil worked fine, just wanted ease of use so i could make longer carefree trips.. Just hook power plus (red) to side of resistor that has 12 volts going in ,, and your good to go.
