jprimrose Posted August 16, 2013 Report Share Posted August 16, 2013 So I have freshened up my car and came to the flywheel and the gear is all chewed up. Anyone know where I can get a replacement or even just the gear? Quote Link to comment
Morrisun Posted August 17, 2013 Report Share Posted August 17, 2013 I have B210, A14 flywheels, one must have a decent ring gear-and the flywheel may need resurfacing. These guys have ring gears http://www.sonnax.com/product-lines/ring-gears Quote Link to comment
jprimrose Posted August 17, 2013 Author Report Share Posted August 17, 2013 the flywheel looks ok. Im going to give them a call on monday to see how long it will take to get one. Thank you for the info. Quote Link to comment
datzenmike Posted August 17, 2013 Report Share Posted August 17, 2013 Throw the flywheel in the freezer over night. Tomorrow put the ring gear in a 350-400 degree oven for half an hour. Place the flywheel on a flat surface and slip the hot gear on and quickly tap into place. Maybe practice this when cold and be sure that the right side is up. Do NOT ever drop a flywheel. 1 Quote Link to comment
Dguy210 Posted August 17, 2013 Report Share Posted August 17, 2013 Rockauto stocks the flywheel ring gear atp part # za543 $20.79 http://www.rockauto.com/catalog/x,carcode,1208483,parttype,5360 Per the Datsun1200 wiki all A-series ring gears interchange. http://datsun1200.com/modules/mediawiki/index.php?title=Flywheel_Bolts Nissan part number is:12312-18000 ET NO. ENGINE OEM NO. OUTER D INNER D THK(mm) TEETH ETNS-RG016 NISSAN Ring Gear 12312-18000 271 240 10.2 105 Quote Link to comment
jprimrose Posted November 13, 2013 Author Report Share Posted November 13, 2013 So i did purchase one and then before I received it I found one at a junkyard that was in great condition. I guess I have an extra now. Quote Link to comment
