DatsunSwag22 Posted August 14, 2013 Report Share Posted August 14, 2013 so i just rebuilt my l20b motor 280z pistons n new head n i can't figure out the jetting on the carbs. one min over n the next under. dual weber 40 doc. i dont kno wat to do. please help. Quote Link to comment
hobbes_the_cat Posted August 14, 2013 Report Share Posted August 14, 2013 There are some good basic tuning guides pinned on this site. I have found that a Wideband o2 gauge is a valuable tool when dialing in twin carbs. It tells you exactly what your A/F ratio is rather than trying to guess by reading the plugs. Quote Link to comment
flatcat19 Posted August 14, 2013 Report Share Posted August 14, 2013 UniSyn. Brilliant. Or a long piece of small diameter rubber hose. Turn till you barely hear a hiss out of each port. Quote Link to comment
LenRobertson Posted August 14, 2013 Report Share Posted August 14, 2013 I searched YouTube for "Weber DCOE tuning" and found a bunch of vids. I have no idea if they will help you, but maybe worth looking at. A couple of links to Ratsun pages if you haven't found them: http://community.ratsun.net/topic/27094-weber-dcoe-stock-jetting-information/ http://community.ratsun.net/topic/6117-weber-tuning-guide/ Len Quote Link to comment
DatsunSwag22 Posted August 15, 2013 Author Report Share Posted August 15, 2013 do u guys kno wat jets i need? Quote Link to comment
TENDRIL Posted August 15, 2013 Report Share Posted August 15, 2013 wtf is a dco.? DCOE? DCOM? Quote Link to comment
TENDRIL Posted August 15, 2013 Report Share Posted August 15, 2013 jets can get expensive real quick. so are you tuning for street or track ? whats your dizzy setup? cheap o2 sensor can save you some monies/ Quote Link to comment
EricJB Posted August 15, 2013 Report Share Posted August 15, 2013 1 Ignition timing must be set properly. 2 Fuel pressure regulator set at 3psi. 3 No vacuum leaks. Find out what size venturies you have. Venturi size x4 = main jet Main jet +40 = air correction jet That should get you close. Quote Link to comment
