Turbojovi Posted August 9, 2013 Report Share Posted August 9, 2013 Having a problem lining up the fender. I tried loosing the bolt but just spins and spins anybody ever experience this? Quote Link to comment
cruznude Posted August 10, 2013 Report Share Posted August 10, 2013 That really sucks man. Your paint looks real good and what I think you have to do would be okay if primered and or paint in an okay condition. I think what you need to do is get something behind the head of that bolt. Maybe something stiff that would allow you to put some pressure on it while you reversed the bolt. Seems to me that the threads are just not catching and need alittle help there. Mine actually broke off trying to remove it and ended up drilling it out and so on. It was a hassle. Quote Link to comment
nismosilvia Posted August 15, 2013 Report Share Posted August 15, 2013 Try some vice grips then if that doesn't work drill. To me that gap looks correct though Quote Link to comment
Datsunrider71 Posted August 16, 2013 Report Share Posted August 16, 2013 I was seeing the same thing on my too i think that's how they came from the factory old cars never line up good like the new ones Quote Link to comment
MikeRL411 Posted August 16, 2013 Report Share Posted August 16, 2013 Maybe you should tweek the lower hinge if it really bothers you. Quote Link to comment
Turbojovi Posted August 16, 2013 Author Report Share Posted August 16, 2013 Its weird because the drivers side fit perfect Quote Link to comment
TENDRIL Posted August 17, 2013 Report Share Posted August 17, 2013 sheet metal screw at an angle pulls it tight. ive never seen a true fix for it, its a bad rust area, Quote Link to comment
