Z24 turbo?
Dean720Ada
whats the best way to go with z24 turbo set up. If i do a blow through what kind of turbo? And what kinda of carb would be suitable? I have read somewhere you can efi the z24 motor. Can you put a z22et head on the z24 block? my uncle ran a turbo on his z24 but had fuel problems and went through transmissions like no other.
  • Replies 6
You can basically mix and match all Naps-Z and L-series blocks and heads. Drilling for water passages or extended timing covers maybe needed. z24i come with FI from the factory. You can find them in 720 STs and Hardbodies.
Edit: You could also look at at swapping to an L head and running L-series EFI. The necessary parts come up for sale sometimes and aren't astronomical in price. Also check out some of the overseas forums for Z18et head and EFI parts. Those are EFI and turbo from the factory.
