Datsun510mom Posted July 29, 2013 Report Share Posted July 29, 2013 Help! I need to find the carburetor number on my Hitachi but I am not sure where it is. There were some numbers on the choke cover but they didn't look like the right ones. I have a feeling it might be stamped into the metal, probably in some inaccessible place on the rear of the carb. Can anyone help with this? The Carb is on a 1980 510 with a Z20S motor. Thanks! Quote Link to comment
DanielC Posted July 29, 2013 Report Share Posted July 29, 2013 I have found the number on the side of the float bowl away from the engine on a L-16 engine carburetor. But it is very faint. Quote Link to comment
datzenmike Posted July 29, 2013 Report Share Posted July 29, 2013 If looking for a rebuild kit or a replacement usually the year and model car, auto or standard, engine size/type, and if California or not. Most kits are a fuel inlet needle valve, gaskets, accelerator pump, some O rings, clips and instructions for setting float height. Often one size fits all. Quote Link to comment
Datsun510mom Posted July 30, 2013 Author Report Share Posted July 30, 2013 A mechanic at a shop (which, unfortunately, is now out of business) told me that the car wouldn't idle because it needed a new 'power valve'. I have seen this part listed on schematics of the carb, but the rebuild kits i have seen do not include the power valve. One on-line carb kit dealer said they could get the power valve, but they needed the number off of the carb so they would get the correct one. My alternative to rebuilding is to get a rebuilt carb for around $200, but I would prefer to do it myself. So that is my story. And i checked on the float bowl but couldn't make out any distinct markings on it. :( Quote Link to comment
DanielC Posted July 30, 2013 Report Share Posted July 30, 2013 Take some pictures of it, and somebody can probably identify it for you on here. Quote Link to comment
datzenmike Posted July 30, 2013 Report Share Posted July 30, 2013 A mechanic at a shop (which, unfortunately, is now out of business) told me that the car wouldn't idle because it needed a new 'power valve'. I have seen this part listed on schematics of the carb, but the rebuild kits i have seen do not include the power valve. One on-line carb kit dealer said they could get the power valve, but they needed the number off of the carb so they would get the correct one. My alternative to rebuilding is to get a rebuilt carb for around $200, but I would prefer to do it myself. So that is my story. And i checked on the float bowl but couldn't make out any distinct markings on it. :( . That makes no sense at all. The power valve adds extra fuel to full throttle to make it run richer. Idle is on it's own sepapare circuit. Quote Link to comment
Datsun510mom Posted July 30, 2013 Author Report Share Posted July 30, 2013 Well, I guess perhaps that is good news for me! I'll try rebuilding the carb and see if that cures the problem. That is, unless you have any other suggestions! ;) The car was running fine but then started to stall at idle. it became increasingly worse so that it would have to be revved up when at stop lights to stay running. The shop said it was the carb, but if they didn't diagnose the power valve problem correctly then perhaps it's another issue?? Quote Link to comment
