Absolutely no electric
Car wouldn't start. No electric what so ever. Not even lights.
Replaced the ignition. Full barrel. The car was stolen at one point and the wires had been hacked and refitted with new connectors.
Replaced the alternator.
Replaced the battery.
Replaced the fusible link and it started right up. Took it for a drive and parked it.
This isn't my daily so it sat for about 2 weeks. When it was time to move it the problem was the same. No electric.
Came back to it later and decided to replace the negative battery cable. The old one was pretty crappy.
Still nothing. Stumped.
  • Replies 5
You said you let it sit for two weeks... maybe the battery is dead. If you had to replace a bunch of messed up wiring after a theft, I bet you have a power drain somewhere. Hook your car up to a charger or swap in the battery from your daily and see if it cranks over. If it does, you have a draw that is killing your battery when you let it sit.
This is a waste of time without a $5 test light. You can't see 12 volts so you need a lamp to tell you it's there.
