Jan_280Z Posted July 4, 2013 Report Share Posted July 4, 2013 Hey lads I'm doing a 5 speed swap in my brother's truck - we pulled the 5 speed out of a 79 620. (or it was labeled that way). I'm wondering what gear oil you guys are using in said transmission. I know its supposed to be GL-4 but are there any specific ones? I use Redline in my Z but that's not on the cheap side in stores. Thanks Jan Quote Link to comment
datsunaholic Posted July 4, 2013 Report Share Posted July 4, 2013 The Z and truck trans are the same, so you use the same stuff. GL-4 isn't easy to find, all I've found recently that wasn't excessively expensive is Sta-Lube. Quote Link to comment
datzenmike Posted July 4, 2013 Report Share Posted July 4, 2013 The 620 and z/zx use the same transmission type so redline is fine. What's your transmission worth to you? Would $20 be so much to protect it and keep it running for the next 30 to 50K? That's $0.004 per mile over 50K. A cent every 2 1/2 miles. Quote Link to comment
Dawa Posted July 4, 2013 Report Share Posted July 4, 2013 napa was the only place i found that had a true gl4, stalube, as mentioned above. oreilly, autozone, pepboys, and one other didnt have it. Quote Link to comment
Jan_280Z Posted July 4, 2013 Author Report Share Posted July 4, 2013 I don't mind using redline but all the places here that sell it will be close tomorrow. I could hunt around tomorrow for true GL-4's but time is not on my side as I only really have one day to do this all. Quote Link to comment
Dawa Posted July 4, 2013 Report Share Posted July 4, 2013 let your fingers do the walking. call napa. if they dont stock it, ask em the nearest napa that does. google synchromax yourself. i did, didnt like what i read. so went with stalube Quote Link to comment
