small disk brakes
HonSun
  • Replies 4
um stock 510 can run 13s.... there you go.. .put a wilwood or other big caliper on it and your good, or run 2 calipers... and before anyone says thats a bad idea they do it in race car setups all the time so the whole rotor is covered......
i should have mentioned that i have a 521, but am seriously concitering loosing the 6 lug and going to 4 or 5 lug.  the truck is never going to have 1000lbs in the back of it and im sick of looking for the wheels i want..lol
looking for a small disk setup, wanting to run 14-15" wheels if possable. any input? was looking at wilwood stuff but it costs a lot
720 vented rotor brake assembly will clear 14 inch rims.
You will need a brake caliper kit to convert to disc brakes. Check here at  Ratsun . Then get Hardbody/late 720 or whatever calipers and vented rotors. Fuck 4 and 5 lug stop looking at bling rims and get something for a chev/ford/toyota/Mazda/Courier/Trooper/720/D21 Hardbody/Xterra.....TRUCK.
