lanechurch920 Posted June 24, 2013 Report Share Posted June 24, 2013 If i do a 4/3"tbar block drop will I need to get shorter shocks? if so what shocks will i need Quote Link to comment
Guss517 Posted June 25, 2013 Report Share Posted June 25, 2013 I believe u will in the front, the shocks to get are ford pinto shocks! I have a 85 720 , i want to lower it to, thats what i've read! Quote Link to comment
datzenmike Posted June 25, 2013 Report Share Posted June 25, 2013 Better to cut the mount off and relocate higher. The 720 isn't a pinto. Would not the truck bottom on the rubber stops long before the shock? Quote Link to comment
lanechurch920 Posted June 25, 2013 Author Report Share Posted June 25, 2013 What drop front and rear can I do without having to change shocks or move mounts Quote Link to comment
Dawa Posted June 25, 2013 Report Share Posted June 25, 2013 nothing.. or almost nothing. if you lower the car upfront without relocating the mounts, the shocks become compressed and have less compression travel, so you may blow the shocks sooner. Quote Link to comment
wayno Posted June 25, 2013 Report Share Posted June 25, 2013 The 720 is way easier to lower than the early kingpin trucks, the 720 front shock is longer than the 521 front shock, so when lowering the 720 in the front, try using the 521 front shock. BTW, I have looked at 3 different shocks side by side at baxters, the 521, the pinto, and some other shock that was supposed to be short, the pinto shock was not shorter than the 521 shock. Datzenmike is correct, the bump stop will hit before the shock bottoms out, but most cut or remove the bump stops to get moar loar. I like the 720 setup, it is easy to cut out the existing lower shock mounts and remove the sway bar, then one can buy a much shorter stud/stud shock, and mount it in the sway bar mount hole, but the front end geometry is totally screwed up when you go that low unless you start modifying everything else also. The pinto shock is made for a small car, it's hard to say how well it will work on a heavy 720 truck. This is the best way to go with a 720, nothing gets screwed up geometry wise, it might not work with stock wheels though. http://www.ebay.com/itm/Belltech-Drop-Spindles-2-for-83-97-Nissan-720-Hardbody-2005-/281097183040?pt=Motors_Car_Truck_Parts_Accessories&hash=item4172b29f40&vxp=mtr Quote Link to comment
