datsILL Posted June 24, 2013 Report Share Posted June 24, 2013 Will a 06 Subaru fit in a 510? Quote Link to comment
Tristin Posted June 24, 2013 Report Share Posted June 24, 2013 The newer 04-07 (?) Subi diffs run 27 spline stubs where the older ones run 25... you need the 25 spline stubs. You can get adapter stubs but they are pricey. Quote Link to comment
72240z Posted June 24, 2013 Report Share Posted June 24, 2013 Well the question was if it fits lol, ya it fits. The 100% bolt in r160's are way before 04, like 85-90 clsd's from XT, GL 4wd's I believe. Prob a bunch of opens work but who cares? lol Quote Link to comment
datsILL Posted June 24, 2013 Author Report Share Posted June 24, 2013 all I wanted to know if it bolt up like the stock one I have a machinist that will make me the adapters Quote Link to comment
Tristin Posted June 24, 2013 Report Share Posted June 24, 2013 all I wanted to know if it bolt up like the stock one I have a machinist that will make me the adapters No it will not bolt up like stock. It will also depend if its an R160 or R180 diff. You didnt give much info... Quote Link to comment
Tristin Posted June 24, 2013 Report Share Posted June 24, 2013 all I wanted to know if it bolt up like the stock one I have a machinist that will make me the adapters He will need to make these: Quote Link to comment
datsILL Posted June 24, 2013 Author Report Share Posted June 24, 2013 So the r 160 will bolt up just got to get those adaptors in a 27 spline Quote Link to comment
72240z Posted June 24, 2013 Report Share Posted June 24, 2013 Yes, an r180 will bolt up as well with with same adapter issue. Depending on your power goals and since you plan to have adapters made anyway that may be a wiser choice. Keep in mind some of the subi mount studs are longer and would need to be swapped out as well as the input flange which is different on some as well on both r160 and r180s. Those adapters are baller btw, many people have successfully cut/welded up their own for much less. Though if you say you have a machinist guess its a non issue. Quote Link to comment
sssr20det510 Posted June 24, 2013 Report Share Posted June 24, 2013 And the r160 will be a vlsd and the 04-06 sti r180 Is clsd Quote Link to comment
datsILL Posted June 24, 2013 Author Report Share Posted June 24, 2013 I can get them for $400 but im getting the diff for $150 r160 vlsd 3.70 from a 2006 subi Quote Link to comment
sssr20det510 Posted June 24, 2013 Report Share Posted June 24, 2013 What motor u running Quote Link to comment
datsILL Posted June 24, 2013 Author Report Share Posted June 24, 2013 With 40.000 miles Quote Link to comment
datsILL Posted June 24, 2013 Author Report Share Posted June 24, 2013 L20b a87 peanut head sss su carbs comp headers Quote Link to comment
sssr20det510 Posted June 24, 2013 Report Share Posted June 24, 2013 Should be fine power wise just remember vlsd when they get hot don't want to lock Quote Link to comment
datrod Posted June 24, 2013 Report Share Posted June 24, 2013 He will need to make these: I just so happen to have about 10 of these in stock. I've been making them for about 2 years now..And I'm pretty sure I'm the machinest he was talking about. Quote Link to comment
72240z Posted June 24, 2013 Report Share Posted June 24, 2013 That exact one? lol Nice work if so Quote Link to comment
datsILL Posted June 24, 2013 Author Report Share Posted June 24, 2013 What's up John... He's the man! Quote Link to comment
sssr20det510 Posted June 24, 2013 Report Share Posted June 24, 2013 how much are the stubs? Quote Link to comment
Tristin Posted June 24, 2013 Report Share Posted June 24, 2013 I just so happen to have about 10 of these in stock. I've been making them for about 2 years now..And I'm pretty sure I'm the machinest he was talking about. Glad to hear youve got him covered :thumbup: That exact one? lol Nice work if so Very nice work! I just took the Beta Motorsports picture... how much are the stubs? I second this. Quote Link to comment
Tristin Posted June 24, 2013 Report Share Posted June 24, 2013 Oh, so just like the others. OK. Quote Link to comment
sssr20det510 Posted June 25, 2013 Report Share Posted June 25, 2013 This is the way I'm going to do my sti rear end http://community.ratsun.net/topic/23651-fs-subaru-r160-lsd-with-custom-cv-axle/ It is cheaper than 500 and u get CV axles too. And no adapters Quote Link to comment
510Finn Posted September 19, 2013 Report Share Posted September 19, 2013 This is the way I'm going to do my sti rear end http://community.ratsun.net/topic/23651-fs-subaru-r160-lsd-with-custom-cv-axle/ It is cheaper than 500 and u get CV axles too. And no adapters Very curious, I want to do this exact same setup as well, but for a 27T splined STi R-180 diff. ssr20det510, update? Did you contact the guy in that FS post, or did you end up contacting Dutchman's in Portland to do this? Did you have to supply the 280zx axle and companion flanges, as well as the Subaru CV joints? Quote Link to comment
