Datsunrider71 Posted June 9, 2013 Report Share Posted June 9, 2013 When I start my 510 with the choke open it starts smoking white smoke but when I close it the smoke stops what's sup with that.. I'm messing around with the carb too so can that be it?? Quote Link to comment
SS320 Posted June 9, 2013 Report Share Posted June 9, 2013 I'm no expert but it sounds like you may have adjusted the air/fuel mixture a little to much on the lean side. You don't exactly say what you were "messing around" with on the carb so a little more info may help solve your problem. Perhaps you may just have to reset your air-fuel mixture by bringing out the screw about 2-3 turns from all the way in when engine is warm. What did you adjust? Quote Link to comment
Datsunrider71 Posted June 10, 2013 Author Report Share Posted June 10, 2013 I adjust the air screw Quote Link to comment
datzenmike Posted June 11, 2013 Report Share Posted June 11, 2013 On a warm engine (assuming valves and timing set correctly) set the idle speed slightly low so changes are more noticeable. Turn the idle mixture screw in slowly until idle becomes rough. Turn the idle mixture out until it becomes rough. Select a spot where the idle is the fastest and smoothest. Turn the idle back down if needed. Repeat this (sometimes 6-8 times) until you cannot improve the idle quality and the idle speed is 750-850. Idle mixture and speed is now correct. Do not do this on a cold motor. On cold start up it's common for a steamy exhaust. Quote Link to comment
Datsunrider71 Posted June 15, 2013 Author Report Share Posted June 15, 2013 datzenmike how you doing.... I have the car running 95% but it still acts up when it wants to and Wast a lot of gas is that Normal? And ruining with no power Quote Link to comment
]2eDeYe Posted June 17, 2013 Report Share Posted June 17, 2013 Not normal. Did you get the mixture set correctly? Quote Link to comment
Datsunrider71 Posted June 17, 2013 Author Report Share Posted June 17, 2013 I don't think so I just get it to run that's it Quote Link to comment
]2eDeYe Posted June 17, 2013 Report Share Posted June 17, 2013 Do you have the stock Hitachi or is there a Weber on it? Quote Link to comment
Datsunrider71 Posted June 18, 2013 Author Report Share Posted June 18, 2013 Stock Quote Link to comment
Datsunrider71 Posted June 18, 2013 Author Report Share Posted June 18, 2013 I just came from Skool I few ago and the car was acting up it got cold out Quote Link to comment
]2eDeYe Posted June 18, 2013 Report Share Posted June 18, 2013 Old Hitachis are notorious for being troublesome. Have you replaced the fuel filters? That usually the first thing I will do when have carb problems. Quote Link to comment
Datsunrider71 Posted June 18, 2013 Author Report Share Posted June 18, 2013 No I haven't Quote Link to comment
]2eDeYe Posted June 18, 2013 Report Share Posted June 18, 2013 I like to run one before the pump and one after the pump. This protects the pump from any debris in the tank and protects the carb should the pump fail and come apart inside. If you are still using the stock fuel pump, you can keep both filters right in the engine bay. I like to use clear ones so I can keep an eye on the filter element. Quote Link to comment
Datsunrider71 Posted June 19, 2013 Author Report Share Posted June 19, 2013 To what fuel line I should put them on Quote Link to comment
