edekalil Posted May 28, 2013 Report Share Posted May 28, 2013 Here is a pic of the lower control arms I took off my car way back. The two rubber bushings (one facing up and one facing down) with a metal insert is what Nissan sold me to replace the old worn out one which I had carefully cut out then cut the outer metal sleave that was pressed in when new. Anyone ever use these? I believe I had seen a replacement that looked like the original made by Moog. Anyone ever replace this bushing? If so any recommendations. Eddie Quote Link to comment
Ratwagon1600 Posted May 28, 2013 Report Share Posted May 28, 2013 Only suggestion I have is to where possible, use OEM bushings (or aftermarket equivalents) Reason being, I always try and run as much positive caster as I can and the OEM bushes are far more flexible than the majority of the aftermarket polyurethane bushes. I also use a little bit of molybdenum grease on the LCA pin. Quote Link to comment
D52E Posted May 28, 2013 Report Share Posted May 28, 2013 I seem to recall that there was a difference between early built cars and later cars. I believe 1968 to 1969 model years had the 2 piece cone shaped bushings and the 1970 to 1973 had the one piece sleeve. Quote Link to comment
edekalil Posted May 28, 2013 Author Report Share Posted May 28, 2013 The cars I have are from the early 70's so maybe he was confused when he gave me the cone shaped ones. So I will have to get the one piece one and still figure how to install it. Thanks Eddie Quote Link to comment
