b210 wheel question
caseyg4017
Hey, I was wondering if anybody knew what width and offset wheel fits best on a lowered b210. My girlfriends Datsun is stock height on 17s and she loves the size but wants to lower it and can't because the will rub. I attached a pic of the Altima I built her and the Datsun I'm building now at a local show. Let me know what you think. 2013-05-19112750_zpsa56fd6c8.jpg
  • Replies 8
That's what I figured, I don't think i'm going to be able to lower it with this big of a wheel unless I get the perfect offset and size or modify the fenders.
The problem with the 17s is the overall diameter of the tire. That is why it rubs.  ;)
You will get a lot less rubbing with a 14" or 15" wheel (assuming proper tire size).
If she is set on having 17s, she is set on this ride height.  ^_^
  • 1 month later...
What offset do you run with the 15x7? they look killer!
Those are a zero offset. In the rear, it's a very good fit. Up front you really only want to go that "aggressive" if you already have 280ZX struts fitted (narrows the track 1/2" per side).
If you are keeping the stock struts, you'd be better off with something in a +10 to +15 range up front.
