r@+5un620 Posted May 20, 2013 Report Share Posted May 20, 2013 Yesterday I performed the side marker light mod with the turn signals I replaced the thermal flasher with an electronic one and wired everything in correctly. I also wired in an aftermarket tach and everything worked perfect the red wire to pos on coil the green to the neg and the white to dimmer switch and the black is grounded out to the cab. It all worked perfectly until last night I drove 100 mi home from college and I hit a pothole towards the end of the trip. The fasten belts light flashed on then off and then I lost my taillights. Then my headlights started dimming and the interior lights started dimming the tach started going backwards and forwards. :confused: The turn signals quit working also. I made it home by my phone flashlight and this morning I go out and all turn signals working until I turn on the headlights then they barely work. I have little knowledge of electrical workings and any help is greatly appreciated. -kyle Quote Link to comment
Dawa Posted May 20, 2013 Report Share Posted May 20, 2013 sounds like a connection was jarred loose from that pothole. Quote Link to comment
r@+5un620 Posted May 20, 2013 Author Report Share Posted May 20, 2013 did I wire my tach wrong the red to the pos on coil and green to neg? I read in other places that it needs to be a switched connection? this meaning ignition switch? :confused: These little things make me angrier than having to rebuild a big project... :angry: Quote Link to comment
banzai510(hainz) Posted May 20, 2013 Report Share Posted May 20, 2013 Dude this is simple. get a volt meter put the meter red lead on the +coil. should read nothing. then turn key on. then should have 12volts. If you still have points with a ballast resisitor you measure going into the ballst resisitor. blk lead will be ground. this is a switchable ignition circut Quote Link to comment
