'76 L20B stock fuel pump w/weber carb....
1042medic
  • Replies 6
  • 3 weeks later...
Sorry guys back online, was gone a few weeks with the Army.
The weber was used when I put it on, it has sat through three deployments and seems to never work the same after I return from each. Thinking about just going back to the stock carb since I can't seem to adjust/work with this weber. I appreciate your help gentleman, just when I start making progress on my 76' KC I get another set of orders!! She's gonna be smiling soon!
have you disassembled it?
id disassemble and clean it. then check the min/max heights of the float.
from everything ive read, you dont connect the return line. i know mine isnt connected.
after you check the heights and reassmble it, you have to adjust the idle speed/idle, and fast idle
(3 different adjustment screws)
