Fckieffer Posted May 8, 2013 Report Share Posted May 8, 2013 I'm doing the ka swap on my 77 620 datsun. I'm buying a already turbocharged ka. Is there anything special I have to do to get it to fit? Quote Link to comment
Fckieffer Posted May 8, 2013 Author Report Share Posted May 8, 2013 Could you specify alittle? Quote Link to comment
Eagle_Adam Posted May 8, 2013 Report Share Posted May 8, 2013 only if you do ;) asking a generic question with no evidence of prior research will only yield a generic answer Lets start with: what did the motor come out of? do you have the harness and ECU? do you know anything about the mounts or what needed to get them to work? have you done any research? what do you know about the swap thus far? ect ect Quote Link to comment
Fckieffer Posted May 8, 2013 Author Report Share Posted May 8, 2013 I do not have the harness or ecu yet. As far as getting the engine in all I know is you have to do something about the oilpan and the motor mounts I have no clue as to how that works I really only have been focusing on the cleaning of the chassis which is now done. That's is why I'm now moving on to the stuff I have no clue about. Quote Link to comment
Eagle_Adam Posted May 8, 2013 Report Share Posted May 8, 2013 http://community.ratsun.net/topic/28097-canam-production-easy-wiring-boxes-for-efi-works-for-kas-srs-vgs-cas-and-more/ http://community.ratsun.net/topic/39780-620-ka24-motor-mount-brackets/ Ill give you these two, the rest you will have to look up, my lunch break is over Quote Link to comment
Farmer Posted May 9, 2013 Report Share Posted May 9, 2013 Theres about 6 threads for 620 going on in the project and truck/620 sections. Lots of readings Quote Link to comment
Fckieffer Posted May 9, 2013 Author Report Share Posted May 9, 2013 Really all I'm asking does anything need to be modified to fit the turbo? Quote Link to comment
highdesertdatsun Posted May 9, 2013 Report Share Posted May 9, 2013 Um ofcoarse it has to be. If it was easy everyone would have A turbo ka . There is a shitload of stuff to research just to plan build budget and plan of attack and then and then.time Quote Link to comment
Farmer Posted May 9, 2013 Report Share Posted May 9, 2013 Depends on the type of manifold. Heres a build to check out. Turbo'd de in a 620 http://community.ratsun.net/topic/20818-ka24de-in-my-620-kc-photos/ http://community.ratsun.net/topic/23800-ka24de-update-and-photos/page-4 Quote Link to comment
