280zx Caliper Piston
Kathos
Im sure you saw this question coming. How do you retract the caliper piston to install pads on a 280zx caliper? I read online you are supposed to twist it clockwise and it screws in. I also read that you shouldnt try to clamp it in because it will strip the internals.
Please help.
  • Replies 2
The rears are screwed in. You could either use a pair of channel locks or buy a little cube which has different tabs made for different types of rear calipers.
The front, I will usually crack open the bleeder and use a clamp or large set of channel locks. You could also take the pads out and use a pry bar and use the rotor to pry on. I always crack the bleeder in case someone added brake fluid as the pads wore down. Plus it flushes out some of the old brake fluid, but it doesn't take a place of a full flush.
http://www.denlorstools.com/home/dt1/page_2453_159/lisle_lis28600_rear_disc_brake_piston_retraction_t.html
